Screw Less Plates Labor
There was a thread asking this that I found from 2015, but the labor part wasn't answered. I don't have screw less plates in my program or in the 2018 NECA. NECA shows 10 hours per 100 for single gang plates, I know NECA is a little high but I always use them for CO's. Any thoughts on labor per 100 for screw less single gang plates?
I certainly wouldn't charge any less. You still have to screw on the inner plate.
That's no question. You should add the three seconds it takes to push the outer plate on. And the three seconds it takes to remove the outer plate so you can install the inner plate. So 600 seconds extra per 100 plates. So 10 minutes per 100 plates. An extra hour of labor for 600 plates.
I'm not familiar with NECA. Are you telling me they estimate 6 minutes per single single gang plate?! Is that including installing the device too?
Rob
.20 man/hrs for receptacle
.05 for plate
don't change anything. You still have to purchase, stock, unwrap, install and fidget to make it fit right
Rob
NECA is the National Electrical Contractors Association and they publish an annual MLU (Manual of Labor Units). It is a little high but they are awesome when you have to argue about change order prices, you can point to the MLU and tell them to go argue with them. It is also awesome for getting a ballpark labor on new things that you haven't done, I used it the other day for a switchboard heater installation CO.
Where do you get one of those manuals?
If your union and join NECA there books are much cheaper. Only reason I might go Union :)
They have some great Literature on any subject you can think of.
