Re: screws for a breaker
What concerns me about replying to questions that are posted is that answers are provided with very little input from the original poster, i.e.the manufacturer of the panel and type. Is the panel new or used?
I recieved a breaker with no screws. There are no screws in the panel.
Is there anything special about screws that bolt the breaker to the panel, or can i use any screw I want off the shelf?
I was more wondering if it is made out of any special metal or if zinc plated would work.
My concern is with different metal characteristics.
Who is the manufacturer of the panel?
If you purchase it new? Then it's a shortage.
Did you call the supplier and what was their answer?
Or is it used? Then you got what you payed for.
One respondent took a "guess" that the panel was a SqD and provided some excellent links, that is assuming that it is a Sqd panel. But is it a GE, C-H, ITE, or? Others gave some excellent reason why not to mess with and use "off the shelf" common fasteners.
Often a manufacture will use a self tapping screw. Remember that the manufacture has received its UL listing with a specific list of breakers installed using specific mounting hardware. If one starts to mess with the screws for the bus then how could the panel ever comply with the UL listing?
There is another item that is often overlooked. Now we should agree that if it is a 'bolt on' type panel, a "NEW" panel as supplied from the manufacturer will be supplied with screws to mount the breakers line connections to the panel bus. BUT ALSO you must have a "breaker mounting kit" which usually includes normally (2) longer screws to fasten the breaker to the mounding rails. This kit usually has to be order as an accessory with the breaker. However, even though these screws are required, they are often common off the shelf screws. It is easier to get them from the manufacture but if you elect to supply them make sure that they are the correct length, have a suitable head, and add and washers that may be required.
Some larger breakers may also require brackets for the load end.
