Discussion at work about setting up generators and switching the neutral (SDS).
The conclusion was that “if” you set up a generator as a SDS then the neutral has to be switched (and neutral is bonded at each source). There appears to not be a code reference that specifically says to switch the neutral but that it’s inferred from 250.30.
Under what circumstances would you choose (or be required) to set up an SDS generator format?
