SDS grounding required?
Take a look at the 3 line diagram on page 2 of this solar wiring diagram in the pdf file in the link below...
http://www.aps.com/_files/SolarRenewable/AllDiagramsSampleNonRes.pdf?source=dg
In the 2400 watt inverters there are DC/AC transformers. Would this be classified as a Seperately Derived System and require grounding according to 250.30?
shortcircuit2
Article 690 covers the rules for grounding PV inverters.
That said ........ yeah there needs to be a GEC.
Thanks iwire...I was told today that 690.3 trumps the rules in 250 on the inverter SDS grounding I thought should apply. I will have to look to 690.47 (C) 2008 NEC as the method that is used. I'm not sure how it is addressed in the 2005 NEC
shortcircuit2
