Seal Fittings
pasqual
New member
Will seal fittings be a technology of the past.
Is the code making it more flexible to eliminate this device with the addition of Zones wiring methods
Re: Seal Fittings
If you mean the seal fitings required by some sections of article 500, I believe they will become a ting of the past when they make things that explode inert and stiil of use. They may change form or change in what we fill than with orsome other method of installation, but some seal of some kinf must isolate source of ignition from fuel.
Re: Seal Fittings
See 505.16. Zone boundries and arc producing equipment within the zones require seal fitting just like in Article 501.
Don
