Does the NEC permit 3/4" seal-tight (FNM) conduit containing power via 8/2 + ground to pass through the steel jacket of an A/C condensing unit without the protection of a grommet? We're the installing HVAC outfit. The ST conduit is, of course, anchored at the local disconnect box and as it passes into the control box within the condensing unit, but passes bare as it enters the unit. Length of the conduit is less than 6'. Although the electrician has wired our units thusly for years, we finally came across an inspector who's raised his eyebrow at the practice. Hole is 1"1/8 and not tight to the ST.
