JoelKline
- Jacksonville, FL
I have a job where I supplied an a chemical skid (with pumps and other components). One of the required components was an Isolator and a Pressure Switch. The idea is that in the event of a leak, pressure would be lost in the line and the switch would hit its lower limit and send an alarm to the nearby panel. The isolator diaphragm (Made of Alloy20 and yet compatible with acid) failed, allowing sulfuric acid to leak into the pressure switch, the switch diaphragm failed (because it wasn?t compatible with the acid). Thats why I had the isolator! Nonetheless, the acid leaked into the switch housing and fried the switch. Acid was able to leak out through the conduit and dripped on a nearby panel causing cosmetic damage.
I replaced the isolator and switch under warranty but believe that owner may say that I'm responsible for replacing the nearby panel.
Here is my question: Do you know if there is any NEC code that states that an electrician is required to seal/isolate the conduit in type of installation? If so, can you point out the that respective language and location? Where an electrical device is installed up on a pressured line. I'm not sure if it matters or not but the pumps are able to pump about 50psi.
