DangerZoneNick
- Garland, TX, US
Good afternoon guys,
I have this intercom unit that has 2 lines coming out the bottom (or possibly just one if we can fit the audio and power cables through the one hole) that is positioned in a Class 1 Division 2 hazardous zone on the outside of the cabin of a drilling rig.
We have ordered some conduit sealing fittings, but the problem arises with the actual process of passing the conduit line through the wall. It's a 3/4''NPT threaded pipe, so we will have to cut a hole in the wall large enough to pass the conduit through, but in order to prevent the gasses from also entering through the wall, we're not sure exactly what to use. My initial thought was to just use a rubber grommet, but others are saying that we also need additional caulking around the ingress hole. However, I can't seem to find any sort of caulking or sealant that's rated for Class 1 Div 2 (besides the stuff that goes inside of the conduit sealing itself).
What are your thoughts?
Also sorry my pictures aren't the greatest, and I can't figure out how to rotate them vertically)
Thanks!
Thanks!
