I'm dealing with a Class I Div I explosion proof solenoid valves in a Class I Div II area (have not found Class I Div II valves that work for my application), which has a potted coil and wire leads. These wire leads will be spliced to a cable inside a Class I Div II Type C condulet threaded directly to the solenoid valve, and the cable runs out to an unclassified area.
Does there need to be a cable gland with a sealing compound on the end of the condulet, or is acceptable to not have the sealing compound?
