Let's say that you were coming in the side of a 3r outdoor ATS at two points, both of these points are "entering above the level of uninsulated live parts" in the ATS.
The first entry is a 2" PVC close nipple, for this you put a sealing lock nut on the outside of the box and a normal locknut on the inside. Good?
The second entry is a 2" PVC connector (male adapter), for this you put the sealing locknut on the inside of the box. Still good?
It just seems odd to do it both ways on the same box, I want to be sure that it is compliant.
Would it be wrong to thread a sealing locknut backwards on the connector before putting it in the box, then install the connector and put a normal locknut inside? This way the sealing locknut is on the outside?
