searching for thread about a member's personal PV system
winnie
Springfield, MA, USA
Electric motor research
I recall a thread where a member described their personal PV system, with some interesting details.
As I recall, they used the panels and racking as the roof, with some drainage arrangement for the gaps between panels. Light passing between the cells made for an interesting skylight effect.
My search-fu is failing me :)
Thanks
Jon
I cheated by remembering the member. : - )
Cheers, Wayne
Cheers, Wayne
Funny, before I scrolled down to your post, I knew exactly who he was talking about.
Yup that's me. It's working great! Dry as a bone inside. One if the best things I've ever built. 4600 KWH of surplus at the annual April zero out. POCO paid me a lofty 2 cents/KWH for my surplus.
I got the building sided and painted, I'll get a picture uploaded soon.
Thanks,
I am just in the planning stages of a solar pergola and wanted to look at what you did again.
Jon
I may have posted this already, but one thing we learned about solar on a wooden pergola is that since there is no decking to tie the rafters together and distribute the load, unless you distribute the dead load from the array equally on all the rafters, over time the more loaded ones will warp out of line with the others. We paid our tuition to the school of experience on two pergola projects a couple of years after they were installed.
I wonder about installing 2x4 purlins, like one would do if they were installing metal roofing. seems like that might distribute the load and help tie everything together? Actually mine required purlins every 2 feet per the truss engineer, but he said I could put them on the underside (they might not have been all installed yet in some of the photos in that original thread).
Thanks,
Jon
Make sure to read post 32 for the surface tension issue. I installed the thing over the winter so I didn't know about that at first. My little surface tension breakers did work and I haven't had an issue since.
Even now that it's been several years, I honestly am not sure I would have done anything different. The only thing I might have done is made my own gutters and made them a few inches wider (I did have an 8-ft brake i borrowed from a contractor friend). For a smaller or less steep system that is more accessible, I would probably just use outdoor rated foil tape
I didn't want to go that route on mine because of the difficulty of replacing it if I ever had a problem.
