tonype
- New Jersey
Is that UF? 340.12 (1) not permitted to be used as SE cable.
Sent from my SM-G935P using Tapatalk
2nd picture (apparently the separate structure end) one of the insulated conductors is wrapped in white tape for some distance at the end. My guess it is being identified as the grounded conductor and there is only 120 volts to this structure.Not being used as service entrance cable. It's being used as a feeder to an overhead line to garage.
Although the bare ground in it should not be used as a neutral conductor, but we cant see how the other end is connected.
What you are calling UV is UF cable.1st pic is at the house - UV feeder from main panel up to service mast (gray cable) - splices in SEC - cuts over roof to garage - 2nd pic shows connections at the garage
