SEC routing
tonype
New Jersey
When an SEC is routed though a roof skirt, is it sufficient to provide a sleeve (PVC) though the roof shirt section only? Or does the entire SEC need to be protected?
I never use a sleeve, just RMC
I don't know about SEC
ABREVIATIONS
AFCI ? Arc Fault Circuit Interrupter
AHJ ? Authority Having Jurisdiction
AHU - Air Handling Unit (as in, Air Conditioning)
AIC ? Amps Interrupting Capability
AC - usually Air Conditioning; also Armored Cable, Alternating Current
AFAIK - As far as I know
AFAICT - As far as I can tell
BTW - By The Way
CB ? Circuit Breaker
CMP - Code Making Panel
DIY ? Do It Yourself
EC ? Electrical Contractor
EGC ? Equipment Grounding Conductor
ESI - Electricians Success International - an organization
FAP (FACP) - Fire Alarm (Control) Panel
FLA ? Full Load Amps
FWIW - For What It's Worth
GC ? General Contractor
GEC ? Grounding Electrode Conductor
GFCI ? Ground Fault Circuit Interrupter
GFI ? Ground Fault Interrupter (technically GFCI)
HI - Home Inspector
HO ? Home Owner
HVAC ? Heating, Ventilation, and Air Conditioning
IIRC - If I Recall Correctly
IMHO ? In My Humble Opinion
IMO ? In My Opinion (used by those who are not humble)
IOW - In Other Words
KVA - kilo-volt-amps
KW - kilo-watt
LABCPB - Lighting & Appliance Branch Circuit Panelboard (408.34)
LMAO ? (I'll not translate this one)
LOL ? Laughing Out Loud
LOTO - Lock Out Tag Out
LRA ? Locked Rotor Amps
MCB ? Main Circuit Breaker​
MCC ? Motor Control Center
MDP - Main Distribution Panelboard
MLO ? Main Lugs Only
MWBC - Multiwire Branch Circuit (see definition in Article 100)
NEC ? National Electrical Code
NECH - NEC Handbook
NEMA = National Electrical Manufacturers' Association
NETA ? National Electrical Testing Association​
NFPA ? National Fire Protection Association
OCP ? Overcurrent Protection
OCPD ? Overcurrent Protection Device
OP ? Original Poster (i.e., the person who started the thread)
OTOH ? On the Other Hand
POCO ? Power Company
PPE ? Personal Protection Equipment
RCI - Residual Current Interrupter (like GFPE, but European)
RTU - Roof Top Unit (as in, air conditioning)
ROFL - Rolling On Floor Laughing
SA (SABC) ? Small Appliance (as in "SA Branch Circuit")
SDS - Separately Derived System
UL ? Underwriter's Laboratory
URD - A cable assembly with no outer sheath, composed of three or more conductors of USE for direct burial.
USE - See Article 338.
VFD- Variable Frequency Drive (could be Volunteer Fire Department too)
WTG - Way to go
List compiled by Charlie Beck, with help from others. :)
Oh , yes , I would definetly sleeve it.
Oh , yes , I would definetly sleeve it. That looks good below, but what about on the roof.
I know, all the abreviations I should know, are not on the list :)
It looks like that clamp is pulling away from the wall. Perhaps the screw only penetrated the shake and didn't "bite" anything solid underneath.
