SCLstandardsengineer
I am in the process of putting together a standard for grounding metallic handhole lids. I was going to bond the lid and frame to a ground rod at the bottom of the handhole. My question is is there an NEC rule dictating whether to bond that to the neutral running from the transformer to the load which passes through the handhole? Thanks
