I am installing a 480V to 120V, 15kVA single phase transformer. I plan on using the secondary lead X1 as the Neutral. I understand that I need to also bond this lead back to the main enclosure's ground point. My question is, what ampacity chart do I need to use in order to size this bonding wire correctly? Should it be sized based off the incoming breaker size (40Amps) or secondary potential (125Amps)?
Thanks!
Thanks!
