Samardas
- Los Angeles, CA, United States
- Electrical Engineer
Hi, I have a design situation as explained below:
It is a light industrial warehouse which a new owner has purchased to rent it out. Although he is upping the utility service power from 1200A to 4000A, he wants to put minimum power distribution to the facility for rental purposes. The new tenant will then do their Tenant Improvement (TI) work as per their needs. Therefore the owner wants to use the existing sub-panels, transformers etc to distribute power to the facility for permit purposes.
In the Single Line Diagram (SLD) I have shown a disconnect switch (on the wall) off of the switchboard on the primary side of the transformer and attached sub-panels on the load side of the transformer. I first thought the sub-panels have main breakers which would also protect the secondary of the transformer. However, upon investigating further I found out that the sub-panels are Main Lug Only (MLO). My question is, can I use another switch on the wall on the secondary side of the transformer just before the sub-panels to meet the code? Or, do I have to convert the MLO to Main CB inside the sub-panels, which I am not sure if it can be done, being the panels to be quite old. I can send you the SLD if needed. Transformers and the sub-panels are in the same vicinity. Your prompt response will be greatly appreciated. Thanks a LOT for your help! - Samar, P.E.
