Ground Loop Guru
- Oxnard, CA
I lecture and write about ground loops in AV systems of all kinds. I have an old note in my files about this section of NEC that specifically prohibits the interruption of the equipment ground connection for plug-and-cord connected equipment (the use of 3-to-2 prong adapters to solve hum and buzz problems in AV systems is on the rise and some new products like "Hum-X" are highly suspect of being totally inadequate to carry actual fault currents (which can range from 100 A to 1,000 A in typical residences, according to a UL study). Was the prohibition in the old (1990)NEC? Do I have the section number wrong? Is the prohibition in the new edition of NEC? Perhaps someone out there has a copy of the old NEC that was in effect back then. Or perhaps I'm just going crazy! ... I have only a 2005 copy of NEC on my bookshelf
