Section 404.8(B) requires a permanent barrier between adjacent devices where the voltage can exceed 300 volts between them. My question is, I have seen where a 120 volt circuit and a 277 volt circuit where brought in to a box. One would be for the lighting and the other for the restroom exhaust fan. With this type of situation can there possibly be 300 volta between the two devices? I thought that the 120 volts which is derived from a dry-type transformer, the two voltage systems would not see each other. Therfore there would not be a voltage potential between them. Please explain.
Thanks
porterh
			Thanks
porterh
