Securing 8 12-2 romex cables
K1GMB
North Chesterfield, Virginia 23236
Telecommunications Engineer (Master Electrician)
Hopefully, I can get some recommendations for what works the best for securing eight runs of 12-2 romex NM cables. I'd like to "stack 'em" for a neater installation, and I have eyed using the GB (Gardner Bender) MCS hangers. From what I have researched, these hangers meet the NEC requirements set forth in Article #334. OK, good, but they are plastic and the "arm" section that folds over and clamps is notched on one end to allow for easy bending. Because the construction is made of plastic, I am concerned about stresses and breakage over time. I have used these hangers before in runs in attics and noticed over time that the arms have popped open. (The NM romex cables were actually secured with these hangers every 3.5 - 4.0 feet), within the 4.5-foot securing rule. Any ideas and suggestions are GREATLY appreciated. BTW, the horizontal runs are less than 15 feet. Thanks!!!!!
Arlington has a similar one without a snap over arm, but frankly, these are generally concealed locations and once installed they should not be used more, so who cares if the "pop" open later?
I prefer the one-piece type, from 3M, Ideal, and others. You can replace the nail with a screw for steel studs.
(I love finding my own pictures on the 'net.)
Often times I would cut a block of wood and install it between the studs on the flat. Then I would nail my cables to that. It usually takes about 2 blocks from a switch.
I don' think anyone addresses the issue but the "stak-it" instructions actually call for a limited number of cables. (I don't recall the esact number but it's less than you often see installed) :)
Yeah I often fill 'em up with 8, 2 per slot, not sure if the destructions say you can do that😞. I'm going to electrician hell no doubt
I may be looking at something incorrectly but that does not appear to offer 1-1/4 set-back.
It was a matter of curiosity... during inspections I would often see so many the have "popped out".. as Starsthead notes: "no big deal;" but it did cause me to look at the instructions on a bag and I was surprised at the limit.
