Securing bids
MGest
NYC
hi All,
Does anyone have some general tips for winning a bid?
Is there a percentage of total bids won that would consider me a successful estimator?
Thanks
I don't really have an answer other than if you get every bid, you're probably too low, and if you don't get any, you're probably too high. If you keep not winning bids with the same people, they're probably just using you as a second or third bid and the job has actually already been awarded.
I always hated bidding jobs. I had enough work from my regular customers, that I usually wouldn't take the time to bid a job, if it was someone I didn't know.
10% has always been a good measure in commercial electrical.
I used to bid around $20 to 30 million a year to hit a target of 2 to 3 million a year in awarded jobs.
Conversely, when I went into business, I figured what my overhead will be for a given year...then, assuming I put 10-15% overhead on my bids...I could calculate an approximate volume of estimates I need to crank out
to cover my annual overhead
