Do attic junction boxes (they are accessible) need to be mounted to the structure or can they be set above the Sheetrock? Also, does code require they be placed above any blown in insulation?
Installing rework style recessed can lights and utilizing existing NM cable feeding surface mount fluorescents.
Would like to junction NM in an approved box and then tail off to can lights.
The attic is accessible, but not someplace I care to work in this week at 100+ degrees.
I could not find where the code requires fastening for this application.
Thank you.
Thank you.
