A few years back I was doing a large 2400 amp disconnect, Upon inspection the inspector had told me he wanted the cable lashed together so as they
won't come loose and dance around in the cabinet. I am now an Engineer for a large company, putting in a 1200 amp 480 volt disconnect, when I mentioned
that they need to lash all the lines going into the lugs, they said that was an old technique and wasn't used anymore. Upon looking at the specs on the
torque specs ect. I noticed there was a notification that wanted all the legs lashed 6" above the connection with 3/8"Nylon Rope. I showed them the Mfg.
spec, and they said the inspector does not check that when they are check torque ect. Is this technique a code requirement? If not must it be done if the
manufacturer requires it on the install labels on the inside the door? Your opinion would be greatly appreciated..
