Crown Electrical
BBKing
- Michigan
- Master Electrician/designer
I have never seen an exterior distribution panel (a panels that feeds 3 or 4 services to different building) mounted on wood. Always on steel.
This makes the most sense, but does NEC 2017 require steel?
I looked in section 408 and did not see where wood was excluded from use.
Any thoughts? Thanks.
