paullmullen
- Wisconsin
- Electrical Engineer & Master Electrician
Curious about how others read 334.30 and specifically 334.30(A) as it relates to securing NM cable in place when running cable perpendicular to and on top of the bottom chord of roof trusses or floor trusses. This is new work and currently exposed, but will be covered with sheetrock.
The way i read 334.30(A), a staple (or other means of securing the cable) is only required at the end of the run of cable and within 12" of its termination. There is no need to secure the NM to each truss along the way.
Clearly, running parallel to the truss is a different matter.
