chevyx92
- VA BCH, VA
Want to set a 112.5 KVA stepdown XFMR 3P 480/208. Primary will be protected at not more than 125%, so 175A 480V breaker feeding transformer. On the secondary side there will be (2) 200A 208V 3P 4W coming out of transformer. Each 200A feed will power a 200A Main Breaker panel for a total of (2) 200A panels being fed from transformer. Anyone see a possible inrush problem on the primary breaker of 175A? Also if needed, can't I increase the primary breaker to 250% if needed which would mean a 350A breaker on primary side? BTW calculated load for both 200A panels would total 290A.
