360Youth
- Newport, NC
I went to do a survey today on a customer that wants to take out an existing 100amp ATS w/breakers and replace with a 200amp ATS to take on one of his 200 amp panels. The house had at one time both 200 amp panels fed back to back of the meter. Somebody, for some reason, has installed a 200 amp disconnect, changed one of the MB panels to a MLO and fed that panel from the disconnect.
I see nothing in the existing ATS set-up that would warrant this "design." The equipment and panels are evryday CH, so it should not be a matter of MB going bad and having to retrofit corrective measures. I did notice as I was putting the covers back on that the MLO panel still has an interlock kit attatched to it, so there used to be a MB and manual transfer system on there at some point. I was utterly stunned and just had to share. :smile:
