Megabyte
- United States
- Engineer
Hello Everyone,
I have been in the controls engineering field for 9 years now at a few different companies. I currently work for the end-user rather than as an integrator or systems provider. Seeing how projects are run from the end-user side is rather different for me. I'm really new to the way this company works, and I do not know how typical it is.
For those electricians who do estimations and run installations, what do you typically receive from the end-user? We are looking for a ballpark estimate for budgeting purposes. The actual install will be on T&M.
The package I have attempted to bid contains the following:
- Explanation of requested services (wire all devices from the designated panel to the field device. Control wiring only, no 480)
- Building drawings with dimensions and major equipment marked
- P&IDs
- Tentative panel locations--We don't have panel drawings yet, those come from our integrator.
- IO list (with the termination panel, the device type, device voltage, pipe size)
- Information for classified area zoning (as in which areas are classified and what enclosures they land to)
- for the classified areas, we know we will be using intrinsically safe components and barriers
- "what fittings are needed for the valves?"--This isn't really something I typically do, I gave them the valve sheet, our spec, and a picture of the valve
- "How do I wire the valves?"--Most are 120 solenoid activated pneumatic valves
- "How do I do wiring on an intrinsically safe circuit?"--I would typically expect the electrical firm to know this. Am I supposed to spec every gland and conduit they use?
