vinod
- Saudi Arabia
Hai
can you explain the use of "semiconductor" tapes in electrical joints (MV or HV)
The semi-conductive layer between conductor and insulation which compensates for air voids that exist between conductor and insulation.
Air is a poor insulation, having a nominal dielectric strength of only 76 volts per mil, while most cable insulation have dielectric strengths over 700 volts/mil. Without strand shielding an electrical potential exists that will over-stress these air voids.
As air breaks down or ionizes, it goes into corona (partial discharges). This forms ozone which chemically deteriorates cable insulation. The semi-conductive strand shielding eliminates this potential by simply “shorting out” the air.
Insulation Shield System
The outer shielding which is com-prised of two conductive components: a semi-conductive layer (semi-con) under a metallic layer (see cable types for common shield varieties). The principal functions of the insulation shield system are to:
1. Confine the dielectric field within the cable
2. Obtain a symmetrical radial distribution of voltage stress within the dielectric
3. Protect the cable from induced potentials
4. Limit radio interference
5. Reduce the hazard of shock
6. Provide a ground path for leakage and fault currents.
All of the above is from this 3M document.The cable’s two shielding systems (strand shield and insulation shield system) must be rebuilt when constructing a splice. The same two methods are used as outlined in the reinsulation process: tape and molded rubber.
For a tape splice, the cable strand shielding is replaced by a semiconductive tape. This tape is wrapped over the connector area to smooth the crimp indents and connector edges.
