Sensor type?
220303-0943 EST
Use an ohmmeter to measure resistance. Use both polarities. If the same resistance for both polarities, and resistance is in the range of possibly 40 ohms to 10,000 ohms it may be a thermistor. Change its temperature from room to 0 F to possibly 140 F for a test.
1. Does resistance change, and remain of same value for both + and - polarity? If so, then it is probably a thermister.
2. Change to a low millivolt range. Change temperature. Does voltage change with temperature? Maybe works in one polarity vs other. If voltage changes, then probably a thermal generator.
