Interested in a more learned opinion on this topic.... distribution designs where an entire service is backed up via a standby generator and SE rated ATS.
I understand a separate ATS is always required for Article 700 loads (Emergency lighting), but I have a question on where the NORMAL supply to the "Article 700 - EM Lighting" ATS typically connected? I have see (and installed) instances where it was connected somewhere on the load side of the main SE ATS, but tend to think that would defeat the purpose of switching these loads separately....the downstream ATS would react to the ATS upstream.
Would a better option be to have a separate service disconnect tapped ahead of the main SE ATS?.. typical to just have two mains on the building in this instance? I would love to hear some more experienced opinions on how this is typically designed and the reasoning / advantages.
FYI....the standby generator would have two separate load breakers....one for each ATS.
Much appreciated in advance
