Shockedby277v
- Michigan
So let's say you are feeding a separate building with 480v 4w 200 amps. You would need a new grounding system at building B. Ok, the feed coming from building A to building B (underground with no metal parts) would it require a equipment ground??? and/or would it be considered a EGC??
