fisherelectric
- Northern Va
Other than 110.3(B) what other code section would require a hydromassage tub to be on a "dedicated" GFI circuit? I don't know the HP or amperage of the motor.
680.71 Protection.
Hydromassage bathtubs and their associated electrical components shall be on an individual branch circuit(s) and protected by a readily accessible ground-fault circuit interrupter. All 125-volt, single-phase receptacles not exceeding 30 amperes and located within 1.83 m (6 ft) measured horizontally of the inside walls of a hydromassage tub shall be protected by a ground-fault circuit interrupter.
Other than 110.3(B) what other code section would require a hydromassage tub to be on a "dedicated" GFI circuit? .
