Separate circuit to pole barn, bonding?
shamilton
New member
Hi,I'm running a separate feed to a pole barn. The meter can must be within 3' of pole, can I run three wires from can to pole barn and bond in the distribution panel and drive 2 ground rods.
Thanks, Scott
I am assuming this feed is via utility, not other on-site distribution. Pending review of local utility requirements, yes.
Where is service disconnecting means?
Is your mentioned "meter" essentially the utility supply or is there a service disconnect ahead of it somewhere?
