dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
Going thru grounding/bonding videos and i have a question concerning transformers and a common instance in my factory 480VAC Y input Use 2 hots and ground to make 120v/240v single phase system
480VAC feed from MCC 3 wire (no neutral) from breaker.
2 of 3 hots used for transformer primary and ground.
Ground from MCC breaker would be only ground wire.
Run 4 wire to 120v/240v panel from transformer secondary (ground and neutral joined at transformer.
Question In the videos it generally shows at transformer secondary some form of electrode added is this necessary?
