Separate structures
tshephard
I have looked a bit, but still...
Residential: my worst example...
A main house, a breezeway pad, and then a garage. Breezeway often roofed, maybe even screen-porched. Final looks like single structure, we know built in stages. (My foundation AHJ says within 5 foot is same structure.)
For NEC purposes, can I find an authoritative definition?
THX
I believe the NEC is either vague or very definitive on this; depending on which way you look at it. "structure, separate" is not defined in Art 100 definitions, so you're left with the AHJ's interpretation of what "separate" means here. That could either allow for wiggle room to go either way in your scenario for example, or make it blunt to the word separate.. i.e. 'separate' means 'separate'... if they're connected, they're not very 'separated'... clear as mud?
IMO if they're connected by a breezeway there is no way that they are separate structures.
I'm not sure what this even means. In some places there are houses less than 5' apart.
What I meant was I know I called the foundation inspection group once and they told me within 5 foot was same structure - so ties, etc were required.
But in my general case for electrical, where does time play in?
I could make a case that my breezeway, if poured concurrently, made the house/garage a single structure.
If planned / on the plans...?
It has nothing to do with time. If there is a roof connecting the structures then they are usually considered one unit.
