Re: Separate systems
And here's the longer answer:
Let?s start by backing up one half step, and being a bit more precise in our choice of words. Ed?s answer would be correct, if Bob?s question made correct and proper use of the phrase ?emergency generator.? But I have heard the word ?emergency? used many times, and each time improperly, when the equipment was not subject to the rules of article 700.
A facility might have a generator on-site, and that generator might be capable of automatically starting and taking on load when the utility feed is lost. But that does not make it an EMERGENCY generator. The phrase ?emergency generator? should only be used when, as article 700 says, the system is ?intended to supply, distribute, and control power and illumination essential for SAFETY TO HUMAN LIFE? (my emphasis).
If a store owner wants to have a generator on-hand so the cash registers can still operate, then we are not talking about emergency equipment. There are also ?Legally Required Standby? systems (Article 701) and ?Optional Standby? systems (Article 702). Neither of these two articles prohibit the configuration that Bob has described.
So back to you, Bob: Are you truly dealing with an ?emergency system,? or is this a ?standby? system?
