Lady Engineer
- New Jersey
Ok, I have a question.
I have a generator which is wired as a separately derived system. The generator is not directly connected to a transfer switch, but is directly connected to the emergency panel via 400A breaker. I have a 4 pole switch, so therefore there needs to be grounding on the generator side. If I ground the system at the generator, I know I need to carry a equipment grounding conductor.
My question, what happens if I decide to ground the system at the emergency panel? Do I still need to carry equipment ground, because we haven't grounded the system until we reach the emergency panel.
What do you think?
What do you think?
