Jlelectricllc
- Sneads Ferry, NC
- Engineering Technician, Electrical Contractor
Currently have a Barracks under construction. Have 1000A 480V MDP fed from pad mount transformer. Terminated at MDP, have the two ground rods, cold water bond, Gas line bond, comm. rack bond and rebar ground. Then we have a step down dry type on all three floors, so copper bus bar has been installed on each floor for the separately derived systems. A grounding conductor has been installed from floor to floor and a grounding conductor has been installed to the dry type transformer. On the first floor a grounding conductor goes directly to grounds rods. The contractor has installed a grounding conductor from the grounding bus bars to the MDP on the first floor to pick up his other bonds inside on the panels ground bar.. I feel that is incorrect and could cause an issue bonding the two systems and also be a path for a fault
Sorry for being confusing, but hard to explain. Any thoughts?
