Ross Thompson
New member
What is the separation between Category 6E cable and 12.5KVA Electrical Cable on a two layered basket tray install with the power in the top tray and the low voltage in the bottom tray?
Actually, the are in separate support systems.. . . They would have to be in separate raceways, and they are.
You can also switch over to shielded CAT6 to eliminate some interference, but there is a definite premium.
and just how would shielded cat6 cable be any better?
Now that I check the prices of media converters, I would just use fiber. you can get copper to fiber converters for as low as $65
~Matt
