Using the 2014 NEC.
Does 517.30(F) allow me to run a single feeder as shown in the second diagram of the attached PDF?
Or does 517.30(F) only apply to a feeder directly connected to the alternate source?
517.30(F): Feeder from Alternate Source Power: A single feeder supplied by a local or remote alternate source shall be permitted to supply the essential electrical system to the point at which the life safety, critical, and equipment branches are separated. Installation of the transfer equipment shall be permitted at other than the location of the alternate power source.
517.30(C) basically says the critical branches have to be kept separate from other branches. But I'm not sure if this also applies to the emergency feeder to the ATS, or if it only applies to the wiring after the ATS. At one time, the ATS was the point where all the wiring had to start being separated, but with all the code changes to emergency systems, I'm not sure if this is true anymore.
If (C) only applies to the wiring after the ATS, then I don't know why 517.30(F) would even be needed. Because if there isn't any code requirement to keep the ATS feeders separate, then we wouldn't need a paragraph to tell us that we can use a single feeder.
View attachment ATS Feeders.pdf
