Poindextrous
- Berkeley California
- General Contractor
Try as I might, I have been unable to find what the required separation is for a buried electrical conduit from both water and gas lines. I'm looking for the required separation when the lines are parallel, and when they cross over each other. In addition, what constitutes a "wet line"? For instance I have both downspout tight lines and perforated pipe French plastic drain lines, do these count as well? I have both those drains and a sewer lines all converging at a corner of a building where I need to also bring down and into the ground both the 2" conduit electrical feed (225 A, 24O V) for a new residence, as well as a copper water line. I'll need to cross them over each other in some fashion to send them to a new residence. Code references, diagrams, and practical advice for when the descriptions don't match reality appreciated.
