mayor43822
My customer has set a new double wide home on a crawl space . Service
was built on a pole within 30 ft. of home and grounded at pole and an
additional uferground from footer was ran back to service at pole .
Feeder to home is four wire , local inspecter wants an additional ground wire from electrical panel in home connected to ufer , there reason for this is they are considering the home a seperate structure and would require an
additional ground , following 550.32 for service placement would you be
required to call it a seperate structure and add the additional connection
to the ufer ?
to the ufer ?
