Oh can't a dead horse just rest in peace?!?!
I tried reviewing previous posts, but am still puzzled..
On a residential property, there is a MeterMain mounted all alone 180ft. from where the first subpanel on a pump house is, and then an additional 210ft. to a house with the remaing loads to be used. The idea is to feed from the main where no loads will be directly utilized (only the feeder) to a Subpanel on a pumphouse 180ft away, and then tap from that panel an additional 210ft. to the subpanel for the house.
So basically I have a pole mounted main feeding its service in parallel -?) to one structure and then to another (house) as opposed to two seperate feeder runs from the main...
Does this special circumstance affect the way that I design/terminate my grounding system? Do I bond my grounded conductor to the grounding electrode at each panel/structure, or still only at the main??
Thanks for aiding in my attempt to being a well grounded individual
Don..
Don..
