Seperately Derived System
tim89s
Brush Prairie WA
Lets say you come off a 480v panel and set a transformer and then go to 208v panel. Is that 208v panel considered a seperately derived system? If so does it mean your have to ground and bound as if it was a service?
bphgravity
Florida
Re: Seperately Derived System
See Article 100 Definitions for Separately Derived Systems. I do not believe your installtion qualifies. If you determine you do have a separatley dervided system, the grounding requirements can be found at Article 250.30. (NEC - 2002)
Ed MacLaren
This 208/120 volt installation appears to be a separately derived system as you describe it.
Ed
bennie
Esteemed Member
Ed: Consider this as a distribution transformer, owned by the utility.
Draw a transformer connected by the MGN system.
I would like to compare the two systems, as shown, from an electrical aspect.
