erfitz1208
- St. Petersburg, FL
we recently did a lighting job where we removed ballasts and lamps that were 277volt. we installed a stepdown transformer to change over to 120 volt LED lights. we tied the ground wire and neutrals together on the load side. as we were told a transformer load side is a seperated derived system and needed to be re-grounded. were we correct in doing that?? what is the correct way to do this?? thank you
