riverjig87
- Minot, North Dakota, USA
We are installing the electrical system in a hospital. Each floor has its own electrical services. They are fed from the main gear downstairs. On each floor, we have 120\208 and 277\480 services. The question is since every floor has med gas pipes, med vacuum pipes, and cold water, do we need to run a seperate bond from the xo of each of these transformers to these pipes passing thru each floor? Does this suffice for the bonding requirements of the seperatly derived systems? ( My logic is that these systems are adding a difference in potential so they must be bonded in order to make the zero potential needed for a grounding system) Also, each floor has a grounding plate that serves as the grounding electrode, located directly underneath each electrical room.
I am not certain that I overthought this to death and would like clarification.
Thanx for any input.
