Septic alarm on separate circuit
electrofelon
Cherry Valley NY, Seattle, WA
Hey guys so I have this septic control panel, and I got dinged on a local code requiring the alarm be on a separate circuit. This job is 4 hours away and unfortunately I dont have a picture of the control panel, but I do have a picture of the wiring diagram. So its a bit of a long shot, but is anyone familiar with these and can the alarm be put on a separate circuit? Hopefully someone with more experience with these can help. My recollection from when I wired it is that there was NOT provisions for pulling the high level alarm off to a separate circuit. IS that typical? Am I mistaken?
JMO but separate circuit for alarm is still useless if it trips, gets turned off, something fails and nothing indicates you lost power to the alarm system.
If it is something critical enough you need something with battery backup and at least some sort of trouble indication telling you there was a power failure. If you have that, then no good reason the alarm can't be on with the pump.
I run them off a lighting circuit, such as the bath lights or kitchen lights.
It’s dumb-they are in separate circuits- one has a 20 one has a 10–
I do one and done- the old system was were you need a circuit separate from alarm now days you don’t need
