Septic Pump Wiring
Little Bill
Tennessee NEC:2017
Semi-Retired Electrician
I was asked by a fellow electrician if you can run the power cord for the septic pump and the wire for the high level float in the same conduit? I'm not sure if this gets into the "Class" wiring or not. So I will forward his question to you guys.
Assuming he is asking about one of the small residential pumps (non hazardous classification),, see it all the time. One could say that conduit is just a protective sleeve for the cables.
Thanks guys!
I figured since the cord was part of a listed assembly and the alarm wiring is associated with the load that it would be allowed.
