MooseOverlord
- New Jersey
- Electrician
Hey guys,
I recently had an issue come up with an install of a 200 amp service with an outdoor 200 amp breaker enclosure as the means of disconnect. It was mounted meter on top, disco on the bottom. The problem arose when I exited out the right side of the disco with SER into the wall to the Main Panel. I used a 2” regular SER squeeze connector. I’ve not yet seen a “watertight” connector in 2” for SER. It’s been my understanding that because the factory knockouts are low on the side that “watertight” conns are not required. Any “live” parts are higher up inside the enclosure. Water can’t get to them. So, since I failed my only solution so far is to replace the cable and loop into the bottom. I’ve seen, installed and passed inspections when using a regular squeeze connector in the side of the meter pan before. I can’t seem to find anything in the code book that would show that what I did was wrong. Has anyone encountered something like this? Installing Main Disconnects outside for services is required but I have never had a problem using the side hole before and now I’m wondering how to tackle it going forward. Thanks.
