electricalperson
- massachusetts
we have some 2/4 SER cable thats marked XHHW insulation on the outer covering. is this used as a 60 degree cable or 75?
XHH --Indicates a single conductor having a cross-linked synthetic polymer insulation with no overall covering provided, rated 90?C dry.
XHHW -- Indicates a single conductor with the same description as Type XHH, except that it is rated 90?C dry, 75?C wet.
UL White Book ZKST:
But he is not using a single conductor..
~Matt
I don't use single conductors when I install NM, either.
depending on the code cycle - nm is 60 degree though.
~Matt
Check to see if the conductors are -2 type that allows 90C rate for both WET or Dry.
There are almost no instances where we can use the 90 C rating of SE regardless of it being XHHW-2 or not.
With the changes in the 2008 NEC SE used as indoor feeder or branch circuit conductors is limited to the 60 C rating.
Used as service entrance conductors we are limited to 75 C rating due to the rating of the devices it will connect to.
you keep referencing nm does the 60 degree also apply to rx when ampacity is involved?
Flattery'll get you everywhere. :grin:you guys are great
